best brakes for 15 inch wheels
Old May 27, 2010 | 07:01 PM
kammi10's Avatar
Car: 1989 camaro
so im looking for the best or biggest brakes i can fit behind my summit race star wheels. they are a 15 in wheel but i also want them to not look tiny when i put a set of 17's on it to cruise with.
i have a completely stock set up in front but have a 9 inch in the rear with s10 drums. that i would also like to switch out for discs..
any opinions?
Old May 27, 2010 | 07:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: best brakes for 15 inch wheels
The biggest brakes you stuff inside a 15" wheel will look small inside a 17".
An option for rear disk
https://www.thirdgen.org/forums/brak...ferential.html
Old May 27, 2010 | 09:49 PM
kammi10's Avatar
Car: 1989 camaro
damn thats a slick rear set up.. thanks.. that should come in very handy
Old Jun 8, 2010 | 07:14 PM
kammi10's Avatar
Car: 1989 camaro
back up top... any suggestions?
Old Jun 9, 2010 | 08:36 PM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Wilwood makes a kit with 11" rotors for the front that will fit under a 15" wheel:
http://www.wilwood.com/BrakeKits/Bra...emno=140-11012
They also make a kit with 12.19" rotors and a parking brake integrated into the rotor hat that will fit under a 15" wheel:
http://www.wilwood.com/BrakeKits/Bra...xleoffset=2.36
That rear kit isn't an exact match to you 9", but it gives you an idea of what Wilwood has to offer.
Old Jun 9, 2010 | 10:52 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I put 4th gen brakes all the way around on mine, but the wheel design is important for them to fit. I had to do some grinding on the calipers to make them clear the wheels, but they fit with my Z28 wheels. I had some summit street stars on the car at one time also and I think the 10" wide ones fit, but the 8" wide ones didn't because of where they place that really small diameter in the wheel to aid in mounting the tires. If you were to use wheels for a newer vehicle with more backspace and put some 1.5"-2" spacers on too, that could work. My best advice would be to find someone with a 4th gen and see if your wheels have a chance of fitting.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
