New LS1 front brakes -One side locks up?
Old May 15, 2010 | 12:28 AM
mike_c's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
I did the LS1 brake conversion about a week ago and under normal braking it stops fine and doesn't pull. But when I get on the brakes hard, the passenger side front will lock. What would cause this? I would think that both should lock at the same time. The pedal is nice and firm, but would improper bleeding of the lines cause this to happen? I just need a point in the right direction before I start pulling things apart again...
Old May 15, 2010 | 12:34 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: New LS1 front brakes -One side locks up?
were the discs new? did you change the rubber hoses?
Old May 15, 2010 | 12:39 AM
mike_c's Avatar
Oh yeah, forgot to mention It's new everything. Pads, rotors, calipers, and stainless lines.
Old May 15, 2010 | 12:44 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
what about the proportioning valve, are you using the correct one?
the only thing I can think off is maybe debris in the caliper or hose..
Old May 15, 2010 | 12:55 AM
mike_c's Avatar
It's the proportioning valve for PBR rear discs. You're not supposed to use a different one if you swap in LS1 fronts, are you?
Old May 15, 2010 | 08:18 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I have drum rear, LS1 fronts, with the stock prop valve... Got it all from EbMiller on here works great.
Old May 15, 2010 | 09:58 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If the caliper is OK, then I would tend toward a pressure difference between the two sides. Look at the hard lines for a dent or slight crimp in the line.
If the lines are OK then I'd go back to the calipers. Many years ago I had the same issue with a car. Normal to medium braking was great. Under heavy braking the left front wanted to lock and even made the car pull heavy to that side.
Found the piston seal in that caliper had folded over for about an inch of length. This was due to improper assembly of the caliper. What I mean by folded over, is that a portion of the seal had twisted 90*, then about a inch further along the seal then un-twisted 90* back to the correct orientation.
Note that the seals are a square cross section o-ring.
I was surprised that it never leaked.
RBob.
Old Jun 9, 2010 | 10:55 PM
mike_c's Avatar
-Update-
I ended up re-bleeding the lines and now everything works as it should.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
