9 bolt and 10 bolt axle hard lines the same?
Old Jun 3, 2010 | 10:41 PM
87350IROC's Avatar
Car: 87' IROC
Does anybody know if the hard lines on the 9 bolt are the same as the hard lines on the 10 bolt? This is for 4 wheel disc.
Thanks.
Old Jun 3, 2010 | 11:47 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: 9 bolt and 10 bolt axle hard lines the same?
Depends on the year. If they had the same brakes, ie PBR calipers, most likely the hardlines will match up. But if one had delco brakes and the other did not, then you'll run into different hard lines
Old Jun 4, 2010 | 12:38 AM
87350IROC's Avatar
Car: 87' IROC
Yeah I bought the 9bolt lines from Classic Industries for my 9 bolt and they don't fit, not even close. I'm wondering if I should try out the 10 bolt lines. Calipers are not changing.
Old Jun 4, 2010 | 06:54 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Though the hard lines were for PBR's on a 10-bolt, the lines I purchased from http://www.finelinesinc.com/ were a perfect fit. More choices:
http://www.classictube.com/
http://www.inlinetube.com/
JamesC
Old Jun 4, 2010 | 11:09 AM
87350IROC's Avatar
Car: 87' IROC
James I checked Finelines they have the same part number as Classic. FRA8601S. It doesn't look good. Wait a second, Finelines lists 8601 as Borg Warner with rear drum. Classic shows it as 4 wheel disc. Finelines shows 8602 as generic 4 wheels disc.
Ok I found a picture of FRA8602S and it looks just like what I took of the axle. I'll get the 8602.
Old Jun 6, 2010 | 12:07 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
not that's its going to help but i had taking one side of the hard lines off a 10 bolt from a 4thgen and used it on my 9 bolt
Old Jun 7, 2010 | 11:37 AM
87350IROC's Avatar
Car: 87' IROC
The 8602 part number is the correct one. Problem solved. Thanks guys.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
red90IROCls1
Aug 25, 2015 06:56 AM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
