Brake pads
Car: 91 Camaro RS
Engine: 305 TPI conversion.
Brake pads
My 91 has a 10 bolt posi rear disc from an 85 Iroc. I replaced all four rotors with slotted crossdrilled and cheap pads. This is not my primary car, but want it to handle and brake well. Im replacing the rubber lines with braided hoses, and will flush the lines and add new fluid.
1. What is the best brake fluid?
2. Hawks or EBC pads? and if EBC, which kind? red, green, yellow?
3. Expeirences?
3. Expeirences?
Car: 1985 z28, 1994 Sierra
Engine: 350, 350
Transmission: T-5, 4L60E
Re: Brake pads
I've heard nothing but good things from EBC brake pads. But what kind of driving does your car go through? Daily driver? road course?
Car: 91 Camaro RS
Re: Brake pads
the car is driven on weekends and a few times during the week. Its more of a road course car than a strip car.
Car: 91 Camaro RS
Re: Brake pads
which braided brake lines are better? because of the year diffrence in the front and rear, can i order a set of braided brake lines for a 91 and will it work for the 85 rear on the car?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Brake pads
BTW, I'm satisfied with Hawks.
JamesC
Car: 91 Camaro RS
Re: Brake pads
so the braided brake lines kit for an 85 will work. i thought the 85 brake lines were diffrent than the 91. does the kit come with a braided line coming from the hardline to the rear end?
im getting ready to order the set so when im back from afghanistan i can have it there to install.
Re: Brake pads
They are different as explained above.
I have no idea what brand/kit you're contemplating, but generally kits come with the line you mention.
JamesC
dbrochard
Sep 19, 2015 08:13 PM
