So is it an easy fix?
Old Aug 26, 2010 | 06:18 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
So when getting my 9 bolt ready I noticed the hard lines that go from the splitter to the calipers that the passenger side was ripped from the PO trying to remove it to get a clean remove but ended up twsting it and causin g it to split. It split where the fitting goes into the T splitter then to the brake line that runs with the fuel lines.
Should it be an easy fix? Can I just cut it a bit further and then use a fitting for the T splitter and then from the line cut to merge them? Should the fitting be easy to get and probably be carried at a local parts store like Autozone or Napa?
Thanks,
Carlos.
Old Aug 29, 2010 | 12:34 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: So is it an easy fix?
Get a new chunk of brake line and replace it. You'll appreciate doing it the correct way the first time somone pulls out in front of you.
Old Aug 29, 2010 | 03:40 AM
Awesome-X's Avatar
Car: 87 Camaro
Are you talking about compression fittings? I use them all they're time and I love the ease and convenience of them.
Old Aug 29, 2010 | 07:15 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
http://www.flynbye.com/catalog/i212.html
JamesC
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
92firebirdguy
Sep 1, 2016 07:53 AM
85 Jimmy
Sep 30, 2015 07:56 AM
