Fitment
Fitment
I have a killer deal on a 12 bolt with 11" baer brakes on the rear and a set of 13" baer front rotors I am picking it all up tomorrow, BUT i have 16" torque thrust II's are they going to fit up front? If they won't fit how much will I need to grind off the caliper (If that will work even). I searched and nothing came up. I really hope this is going to work. Early thank you to anyone
-Josh
-Josh
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Fitment
they should fit the rear no problem, as for the fronts, unlikely, but it has a lot to do with what caliper you are using too. What front brake setup are you using? what are the 13" baer rotors for/from?
Car: 86 Trans Am
Re: Fitment
ok, so its a bare kit. Probably similar caliper to a c4hd? Im not sure on the fitment, you will have to check and see.
if they dont work, and its a killer deal, i would pick them up anyway. You can always sell them, or change wheels.
Car: 86 Trans Am
Re: Fitment
if they are similar to the 13" c4hd's, according to ebmiller, flynbye, they fit 16" wheels, so you may be good to go.
Chad Speier
Sep 24, 2015 12:32 PM
86White_T/A305
Sep 21, 2015 05:28 PM
