thirdgen 4 disk?
Old Oct 10, 2010 | 04:23 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
thirdgen 4 disk?
I just found an 86 camaro iroc with a 305 tpi and it has 4 wheel disk, how common are these on our cars? and also the guy wants $300 for it is that a good price? or can i pull one out of a yard cheaper?
Old Oct 10, 2010 | 04:51 PM
Stephen's Avatar
Car: 87 GTA
Re: thirdgen 4 disk?
Not very uncommon. But are you saying $300 for the whole car? Even a pretty dead car is a good parts car at that price. If you can get in, turn the key & drive home...That is a great price.
Old Oct 10, 2010 | 05:45 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Common enough. Price? Is the rear a 9- or 10-bolt? Limited slip or open? What's the gear ratio? All questions that may determine what you're willing to spend (though $300 seems steep).
JamesC
Old Oct 10, 2010 | 05:46 PM
Engine: L31 350
no $300 for just the rear end.
Old Oct 10, 2010 | 05:50 PM
Engine: L31 350
i just emailed him the other questions. when i get a reply ill post them on here.
Old Oct 10, 2010 | 06:03 PM
Stephen's Avatar
Car: 87 GTA
A bit steep for a 9-bolt. Even steeper for a 10-bolt.
Old Oct 10, 2010 | 06:10 PM
Engine: L31 350
all i know is its factory, anyone know what i can pick these up for from a yard? even out of a fourthgen?
Old Oct 10, 2010 | 06:19 PM
Stephen's Avatar
Car: 87 GTA
All the 4th gen rears will be 10-bolt rears & about 2" wider, per side, for a total of 4" wider.
If you go the 4th gen rear route, get a LS1/98-02. They are a hair narrower than the LT1 rears, the rotors are bigger, the calipers better. The 93-97 rotors are the same size as a late 3rd gen rotor & calipers are only a little better than the 3rd gen calipers.
CORRECTION: I think the LT1/93-97 calipers are identical, but its the center section that is a little better than the 3rd gen ones.
Old Oct 10, 2010 | 06:25 PM
88gta6spdvert's Avatar
Car: 99 3000gt 88 gta vert 88 gta h/t
Engine: v6 /5.0 /5.7
Transmission: at/5 speed/at
Axle/Gears: ? /3.45/3.23
actually hard to get? now so you better or some street rodder will they are why so hard to find cheap disc
Old Oct 10, 2010 | 06:29 PM
not to mention not hardly any salvage yards left everybodys gone to crushing asap around here , scrap is high 12.00 / 100 highest ever.
Old Oct 10, 2010 | 06:51 PM
Engine: L31 350
ok, ill start shopping around, thats stephen....88gta, i cant understand what your trying to tell me, can you please re word that?
Old Oct 10, 2010 | 06:52 PM
Engine: L31 350
is it smarter to go the 4'th gen route or the 3rd gen route? from what iv read they all just bolt on meaning no modification?
Old Oct 10, 2010 | 08:30 PM
JamesC's Avatar
The fourthgen rear is no stronger than a thirdgen (10-bolt) with 28-spline axles. 89-97 cars essentially have the same brake set-up. While the fourthgen rear will bolt in, like the thirdgen rear, there are other considerations, such as parking brake, speedo gears, and combination valve. Check the following FAQ for more details:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Oct 10, 2010 | 08:50 PM
Engine: L31 350
ok, thanks james.
Old Oct 10, 2010 | 08:55 PM
buy it you wont get next time cause how many you seen local forsale 3rd gen now getting hard to find
Old Oct 10, 2010 | 09:05 PM
Engine: L31 350
thats true but as james said i can always get one for a forthgen for cheaper, $300 for jsut a rear end is kinda steep for me since i only paid $250 for the car.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
Warlocksirix
Sep 3, 2015 12:26 PM
