Using a rear disc brake prop valve w/ rear drums?
Old Oct 18, 2010 | 03:25 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I'm going to ultimately be upgrading my rear brakes to disc and have a proportioning valve from a 1990 IROCZ. Will there be any problem to use this in my 91 Z28 with the rear drums until I get the rear disc axle?
Old Oct 18, 2010 | 03:55 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Using a rear disc brake prop valve w/ rear drums?
Probably will not be a problem. If it was it is easy enough to change out the proportioning valve spring to compensate in the meantime. Grainger has an array of springs lighter and stronger than stock that will drop right in. Lighter will mean less brake pressure on the rear brakes. A stronger spring means more brake pressure on the rear brakes.
Old Oct 18, 2010 | 04:13 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
So I couldn't just drop it in and go? If I did, it sounds like the rear brakes would be too tight, correct?
Old Oct 18, 2010 | 07:20 PM
Car: 1989 GTA
Engine: 369 TPI
I would drop it in and see what happens. There is not all that much pressure on the rear disc brakes as it is with that proportioning valve. Might be just right for drum brakes. All I'm saying if there is a problem with the using that valve on the drum brakes you can buy springs and make the corrections one way or the other. Hopefully someone will chime in that has actually done what you are doing.
Old Oct 19, 2010 | 10:26 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
pressures for disk and drum brakes is way different. I don't remember which uses more pressure, you may have no rear brakes or a lot of rear brake with the stock disk brake valve.
Old Oct 20, 2010 | 06:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Some members swap to discs and use their drum combination valve. According to their reports, the car stops fine; however for best brake performance, I'd swap to the correct valve as the bias is apparently different from valve to valve: disc/drum, disc/disc non 1LE, and disc/disc 1LE.
JamesC
Old Oct 20, 2010 | 07:45 AM
88gta6spdvert's Avatar
Car: 99 3000gt 88 gta vert 88 gta h/t
Engine: v6 /5.0 /5.7
Transmission: at/5 speed/at
Axle/Gears: ? /3.45/3.23
Been told , discs require more line pressure.
Old Oct 20, 2010 | 06:51 PM
injdinjn's Avatar
Why change the prop valve before the brake change, you will have to bleed the brakes, why not do it then and eliminate any worries.
hectre13
Dec 11, 2023 08:14 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
