emergency break light wont come on
Old Oct 26, 2010 | 06:59 AM
c9qjyq3's Avatar
Car: 92 Camaro Rs
Engine: CHEVY 350
Axle/Gears: open 2.73
When i pull my emergency brake. The dash break light wont come on. Any suggestions?
Old Oct 26, 2010 | 12:45 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
No Parking Zone
Does the Parking Brake Light come on while you start the car?
If yes, check the switch at the Parking Brake Handle with an ohmmeter while the key is in the OFF position.
You want to see less than 1 ohm on both side of the switch to ground when the Parking Brake is engaged.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Oct 26, 2010 | 04:08 PM
Re: emergency break light wont come on
Change the bulb?
See my signature for a helpful hint from someone much wiser than me, about things like ... bulbs that don't light up.
I don't recall the parking brake / brake warning light coming on during "bulb check" in these cars, but I could be wrong about that.
Old Oct 26, 2010 | 04:47 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
I had the same problem with my car. you gotta remove the shifter plate to fix it. when you raise the Brake lever two copper contacts touch and over time the contact can bend away fro the e brake contact part. You just need to bend it back.
Old Mar 1, 2011 | 09:24 PM
c9qjyq3's Avatar
Car: 92 Camaro Rs
Engine: CHEVY 350
ok thanks will try.
Old Mar 1, 2011 | 10:21 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
jaridjohn
Jul 8, 2024 03:49 PM
Vintageracer
Jan 10, 2020 05:33 PM
Warlocksirix
Sep 3, 2015 12:26 PM
smooth
Aug 18, 2015 06:34 PM
Omega
Aug 10, 2015 12:46 PM
