Can vacuum be affected by tuning
Old Nov 7, 2010 | 12:32 AM
RGV 89 GTA's Avatar
Car: 2001 SS/1989 GTA
I havent really worked on my car in a couple years since i lost interest after having tranny and brake problems. The car has a vortec 350 with a lt4 hot cam and if i remeber correctly I had like 10 psi( or whatever the measurement it). can i mess with the distributor and add more timing? I also just saw this http://www.gmhightechperformance.com.../photo_16.html its the same set up i have but i bought it as a crate engine from sdpc when it recently released, anyone have more info about this.
Old Nov 7, 2010 | 12:37 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Can vacuum be affected by tuning
Absolutely tuning has an effect on idle vacuum. Just look at how the idle mixture on carbureted cars is set with a vacuum gauge, or how full-time vacuum advance is used to increase the idle vacuum with large cams.
I'd expect a mild cam like the LT4 to make more than 10 inHg.
Old Nov 9, 2010 | 09:54 PM
RGV 89 GTA's Avatar
I never got it tuned, do u think I should start there? Back when I installed the motor everyone always said mailorder tunes were junk, and with no one local I never did it.
85 Jimmy
Sep 30, 2015 07:56 AM
Tarizza
Sep 24, 2015 12:57 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
Blkdth87
Sep 16, 2015 01:40 PM
camarohelp
Sep 12, 2015 05:45 PM
