Drilling and tapping sizes for spindles for LS1 brackets?
Old Aug 21, 2012 | 12:02 PM
  #51
blakecharles's Avatar
Re: Drilling and tapping sizes for spindles for LS1 brackets?
Originally Posted by ebmiller88
To keep it simple I normally use a 7/16"-20 on the upper bolt and a M10 x 1.5 button head Allen on the lower spindle bolt. The button head allows the caliper abutment to clear the bolt head, it's very tight in that area. You don't need to go to the larger M12 but that's up to you. Using slightly smaller bolts leaves more spindle material for you.
Ed
So will I need to drill and tap for 2 different sizes. I don't know much about threads and all. I have Ed's LS1 swap bracket and already cut my spindles.
Top
7/16-20 (tap), 25/64 (clearance drill)
Bottom
M10 x 1.5mm (tap), 8.5mm (clearance drill)
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Genopsyde
Nov 11, 2015 10:46 PM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
