replament caliper?
Old Nov 7, 2010 | 02:05 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
replament caliper?
Well just few minutes ago i went to pull out of my driveway and i started spinning tires and ended up digging a hole( literally), well upon further inspection, my driver side caliper isnt wanted to do anything, i released pressure on it since it was locked up and it released off my roter, but now when i step on the brakes its not wanting to close indicating a bad caliper, my question is where can i get a replacement for 15 in rims? i just want the stock replacment.
Old Nov 7, 2010 | 04:09 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: replament caliper?
my bet is that your brake flex line took a dump . they can/will collapse internally and act like ck. valves . change at least both on the front . they are keyed lt. & rt. to the points where the hard lines attach . it's a problem with all older vechicles , happened also on my 89 P/U . good luck .
Old Nov 7, 2010 | 07:08 PM
Engine: L31 350
would autozone have these? they have the calipers for $11.19 so im goin to go ahead and replace both the fronts anyways since they are cheap.
Old Nov 7, 2010 | 08:30 PM
UNCLE TOM's Avatar
yes .
Old Nov 7, 2010 | 08:51 PM
Engine: L31 350
yes .
thank you tom, all in all its gonna cost me alittle over $60 to redo all the front, i might go ahead and keep the caliphers if its just the line that is bad. in time i will do the brakes though.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
the_hamturdler
Sep 30, 2015 12:50 PM
