Need part #'s for front rotor work
Old Nov 12, 2010 | 12:11 PM
Moe87's Avatar
I am getting a lot of road noise with a whining metal strain type sound. It sounds like its coming from the front wheels, likely the bearings need replacing.
I am looking for part #'s to purchase to replace the following:
CAR- 1989 Pontiac Firebird GTA with WS6 performance package
- bearings
Part Number: 4665-07066776
Notes: Taper Bearing Set -- Front Wheel; Outer; Exc. Performance Pkg.
Position: Outer
The 6 at the end as per the guide should work correct?
http://www.partsgeek.com/gbproducts/...ek+Google+Base
- seals
- brake pads
- dust covers
I have never done this before but I have read the 50 step rotor replacement guide and have purchased a haynes guide for visuals, but any assistance you could render on top cannot hurt.
Old Nov 13, 2010 | 09:38 AM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
Re: Need part #'s for front rotor work
The inner bearing is a: A6 and the outer is a: A34 and the seal is a: 8871 As for the pads, it all depends on what you can afford, for a good lifetime warrenty pad you can use part number:MKD154.
If you are talking about the dust cap on the front of the rotor that is: Dorman #13977.
You can find all these parts anywere.
Old Nov 13, 2010 | 07:54 PM
Moe87's Avatar
Excellent, kd5 Thank you very much!
Old Nov 13, 2010 | 09:31 PM
kd5icr's Avatar
Axle/Gears: Stock
Not a problem. I am here to help.Oh and I forgot to add, replace the cotter pins with new ones. that is what keeps the retaner nut in place under the dust cap. I dont have a part number but a pack with a few different sizes will run about 3 dollars, and you will find the 2 you need in it.
Old Nov 13, 2010 | 09:32 PM
Moe87's Avatar
read that in my haynes guide. Will do.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
1nastygta
Aug 8, 2015 07:38 PM
