stock brake size question
Old Nov 14, 2010 | 09:58 PM
sand1303's Avatar
i have a 87 camaro that was built with a v6. i am putting a 350 in it. so naturally thinking brake upgrades is one thing on my list of future things to consider. looking at autozones web site the parts for the brakes on both the v6 and v8 have the same part numbers. did the v6 camaro's have the same size brakes as the irocs and z28? now this is just a simple oem question. i know there is stickies going into details about brake upgrades but i am wandering if the camaro's came with the same factory brake setup through all the models
Old Nov 14, 2010 | 11:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: stock brake size question
The brakes are the same, regardless of which engine came in it.
Old Nov 15, 2010 | 06:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The exception would be the 1LE (performance package), which would have dual piston alum calipers and 11.7" front rotors. A pic can be seen in my vbGarage, located next to my online status.
JamesC
Old Nov 15, 2010 | 12:11 PM
Guest
Guest
Posts: n/a
JamesC
Exactly.
For futher reference the single piston Iron caliper brakes (factory small brakes) are 10.5" rotors, and as James has stated the other performance ones are 11.7" rotors being 1LE.
Steve Millen (Stillen Performance in Costa Mesa Calif) sells great aftermarket support for stock 10.5" brakes. They have very good drilled rotors and Metal Matrix pads that are both combined together make up a VERY VERY good street performance-to-light track duty level while still giving a cold pad performance. Trust me, I highly recommend these purchases IF you are contimplating keeping the factory size stuff. Stay away from Performance Friction or EBC crap. You will have nothing but problems with EBC pads leaving "pad buildup" on the rotors andf that notorious pulsating brake pedal feeling.
Nothing wrong with the 10.5 brakes in stopping power when you have better pads and rotors, BUT there is an INHERIT DEFECT in GM's design that leaves these setups with brake pads rattling in the caliper at very low speeds. There are tabs on the top of the outside pads that need to be bent over but with heat for harder stops they will keep loosing. I changed mine after years of use ONLY to get rid of the ever incuring rattle.
Dean
Old Nov 15, 2010 | 10:11 PM
sand1303's Avatar
ok thanks for the responses. i guess the brakes will stay for now and later down the road if i am not happy i will look into the 1LE upgrade.
Old Nov 16, 2010 | 06:17 AM
JamesC's Avatar
Here's a how-to for future reference:
http://web.archive.org/web/200605221.../1LEbrake.html
JamesC
Old Nov 16, 2010 | 08:24 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There are other upgrades now that are about the same effort, but let you use more commonly-available parts than the 1LE.
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
wruiz
Aug 13, 2015 09:07 PM
knight72
Aug 10, 2015 09:32 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
