Rotor modification question
Old Nov 22, 2010 | 02:00 PM
supr_fly03's Avatar
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
Ok, I will be swapping to LS1 brakes at some point in the future, but I dont have 16" rims yet so there is no point in doing the swap. I picked up a set of cross-drilled/slotted 82-92 rotors (used) and they are in good shape except for surface rust.
Should I sell them, modify them for the conversion, or use them on the car and modify the plain rotors on the car?
Old Nov 22, 2010 | 02:09 PM
Stephen's Avatar
Car: 87 GTA
Re: Rotor modification question
If they have plenty of rotor life left on them....Use them & mod your stock rotors for the LS1 brake conversion later.
Old Nov 22, 2010 | 03:14 PM
supr_fly03's Avatar
Car: 83 Z28
Well that is what I was thinking, the rotors on the camaro are nearly brand new. The C/S rotors have no wear and you can almost still make out the cross-hatch finish on them in places where I removed the rust. Guess I will will just sell the C/S rotors when I do the conversion. Thanks for the reply.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
