Master Cylinder question
Old Dec 12, 2010 | 11:07 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I was reading in one of my car mags and it got me thinking. They were talking about rear drum cars having a special type of master cylinder that always put about 10psi of pressure on the rear lines so that the shoes would be right up against the drums when you go to step on the brakes. My question is..do third gens have this type of master? If so..i need to get another master cylinder for a 4 wheel disk car cause i just found the cause of my slight dragging that ive had from my PBR rear calipers.
Old Dec 12, 2010 | 12:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Master Cylinder question
The only difference between disc and drum master cylinders is the diameter of the bore. They're interchangeable. The combo valves are different, though.
Old Dec 12, 2010 | 03:16 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The residual pressure check valves have been incorporated into the combo valve for a number of years. Older vehicles such as 1st gen f-bodys the residual pressure check valve was in the outlet port of the M/C.
So when switching from drum to disc brakes it needed to be removed.
Also, the purpose of the residual pressure check valve was not to keep the shoes against the drums. A 10 psi valve is not enough to do that.
The purpose was to keep a small amount of pressure on the brake wheel cylinder seals. Which prevented them from: leaking and pulling air into the brake cylinder.
There are other reasons for using residual pressure check valves. Such as having the M/C located lower then the brake calipers or brake wheel cylinders.
In your case you need a combo valve for a 4-wheel disc car. Or eliminate the combo valve and run just a proportioning valve to the rear.
RBob.
Old Dec 12, 2010 | 09:25 PM
subroc's Avatar
Engine: 355 TPI
Ok then im all set. When i did the rear disk swap i put a SSBC adjustable prop valve in.
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
