cant i jus switch rotors n calipers to 1le?
Old Dec 21, 2010 | 10:10 PM
lara9's Avatar
i have 85 z28 with front and rear disc brakes...im trying to figure out how or if its possible to jus switch rotors and calipers to 1le and call it a day...
i know the rotors are larger and spindles are different butt idk if its necessary to buy conversion kit if i can swap parts...
any help wud b great...thanks
Old Dec 21, 2010 | 10:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: cant i jus switch rotors n calipers to 1le?
The conversion kit is a parts swap. You change the spindles (or modify them), rotors, bearings, caliper carrier brackets, caliper carriers, calipers, pads and hoses.
Old Dec 21, 2010 | 10:44 PM
lara9's Avatar
so, in otherwords i havto buy the conversion kit in oder to get the big rotors i want?
Old Dec 21, 2010 | 10:53 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You have to replace a bunch of parts, whether you get them from a kit or individually.
Old Dec 22, 2010 | 06:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following details the conversion for front and rear:
http://web.archive.org/web/200605221.../1LEbrake.html
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Jan 1, 2011 | 07:08 PM
z28m8's Avatar
Car: '91 camaro z28,imsa widebody
Engine: 383 ci l98,lt1 induction
Transmission: race built 700r4 , ratchet shifter
Axle/Gears: 342;1 detroit true trac diff
ive just put a thread on the wilwood brake upgrade part on this forum,,,, take a look. it may help!!??
Old Jan 3, 2011 | 12:08 AM
lara9's Avatar
thanks for the post...im goina need sum free time to read everything butt it seems like alot of reliable n ligit info...
i was looking on hawksthirdgenparts n they got a pretty good deal ontha front conversion kit...im thinkn of jus sendin them my spindles...
rear brakes wud b another story...i already purchased the discs so it looks like i myte havto piece the rears together...
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
