87 IROC brakes
Old Jan 19, 2011 | 05:59 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
87 IROC brakes
During the course of trying to fix up my new acquisition, I did a little brake work. I replaced the rotors all around with drilled/slotted ones. Upgraded brake pads, bled the system. Didn't make much different over stock. I don't really feel like it won't stop, but I do wonder if I'm going to run out of floor. They just don't feel tight. I realize this is late 80's brake tech, but dang. I've done all of the adjustments I can find, it just seems like they are a little bit substandard. Vacuum pressure is fine by the way. Any suggestions are greatly appreciated.
Steve
Old Jan 19, 2011 | 06:25 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: 87 IROC brakes
What condition are the rear brakes in? Did you clean the rotors real good before finishing the assembly?
Another thing I've read here is the need to replace the original rubber lines with either the braided style or new rubber lines dueto the inside failing, thus causing swelling when brakes applied.
IMHO, check all the rubber lines for any swelling when brakes applied. You will need an assistant for about 5 mins to do it.
Old Jan 19, 2011 | 06:39 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: 87 IROC brakes
Rear brakes and rotors were replaced also. Cleaned everything with brake cleaner prior to reassembly.
Replaced the rubber lines on the front when I did the rotors. Car stops straight. No pulling, chattering, etc.
Old Jan 19, 2011 | 08:11 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 87 IROC brakes
Bleed Bleed Bleed is my only other suggestion since you replaced the rubber lines. Start at rear pass, then rear driver, then front pass, then front driver.
Old Jan 19, 2011 | 08:41 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: 87 IROC brakes
Been there, done that too.
Just to clarify, the car stops ok. It just seems to me, with all the things I replaced, it would have a little better stopping power. Not that I condone locking up the brakes, but just out of curiosity, I tried it. 40 mph and layed on it with both feet. Not happening.
smooth
Aug 18, 2015 06:34 PM
kyleb24
Aug 15, 2015 08:24 AM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Leggman1
Aug 6, 2015 04:15 AM
