piston stuck?
Old Feb 17, 2011 | 05:24 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
piston stuck?
i was doing a pad and rotor change and when i got to the rear calipers the piston stuck out just a little bit (enogh to not let it over the rotor) and it would not go back with a c/clamp. what happened and how to fix?
Old Feb 17, 2011 | 08:16 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: piston stuck?
depending on the rear brakes, you may need the tool to rotate the pistons in. they work in conjunction with the parking brake, and something is threaded internally
Old Feb 18, 2011 | 06:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: piston stuck?
If you have PBR's on your 89, try loosening the bleeder screw, then using the C-clamp.
JamesC
tmellott89
Oct 14, 2015 02:06 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
