Line fittings
Old Mar 1, 2011 | 08:08 PM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
Line fittings
I have a 87 iroc putting in a Hurst line lock Hurst is Amer. pro. valve is metric does anyone know what size fit. to the pro. valve an what do I do with the Hurst. to adapt from Amer. to met.Thanks
Old Mar 3, 2011 | 10:32 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Re: Line fittings
You can either cut the end of the stock line, pull the metric fitting off and replace it with a standard then flare it again. However I ended up with lots of leaks this way. Instead I went to a clutch/brake shop and had them make up some lines for me. Lots easier and only set me back about $10.
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
armybyrd
Aug 10, 2015 09:23 PM
