brake booster/strut tower differences? clearance issues?
Old Mar 12, 2011 | 06:28 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
im wrapping up some work on my 92, and i went to install new strut mounts, and noticed a large difference is clearance from the strut tower to the brake masters reservoir. ( its interfering with my custom strut mounts)
so i took some measurements, red marks in this old pic. from the seam in the center of the ls1 reservoir, to the strut tower directly below.
on my 92, i have 3.5". on my 86 i have 4.25". Both cars have stock boosters, ls1 masters, and have never been hit. Is this just production tolerances? that seems a bit excessive, or something else? Did sheet metal change in 92?
anybody with a ls1 master in their car care to grab a measurement?
any ideas?
only thing i can think of is that i converted the 86 to a manual trans, is this caused by the extra pressure on the firewall?
Old Mar 13, 2011 | 04:46 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: brake booster/strut tower differences? clearance issues?
EDIT: I saw the answer to my question after looking closer. Nevermind.
As for your question...Mine is stock, so my measurements wouldn't help you any.
Old Mar 13, 2011 | 09:10 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
4 3/8 on my 87
Old Mar 14, 2011 | 04:24 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Originally Posted by bm87ta
4 3/8 on my 87
is that with the ls1 master or stock?
thanks!
Old Mar 14, 2011 | 09:29 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
ls1 master
Old Mar 15, 2011 | 07:11 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
GM may have changed something over the years. On a stock '92 Camaro (stock M/C & booster), the Spohn strut mount doesn't clear the M/C. I ended up sectioning the mount to clear.
This is with -0.3* camber and 5* caster.
I haven't seen anyone else mention this. Which points to something that has probably changed over the different model year cars.
RBob.
Old Mar 15, 2011 | 08:28 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
RBob.
I was going to clearance my strut mount, but that wont really gain me a whole lot, so i may end up shimming the lower bolts of the booster a little to raise the master. I dont know how much that will affect the boosters pushrod stroke/angle, so i may have to tweek some other things as well.
Old Mar 20, 2011 | 11:52 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i have measurements off another 91 car, and they are also about 3.5", so there is a difference in the booster/firewall that happened at some point over the years.
Old Mar 20, 2011 | 04:46 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
alright, I fixed this issue.
i know this may have possibly cause a geometry issue, i'll find that out when i get the car aligned and drive it, but i shimmed the lower 2 bolts of the booster off the firewall a little over 1/8", and that raised the master 3/4" and now my strut plates clear, and the measurement is the same as on my 86 now.
wonder if this was caused my worn tooling by the time the 91-92's were made or if the boosters are slightly different for some reason? I cant imagine GM would change the firewall over the production run of the 3rd gens.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
