Anything needed for a bolt on deal?
Old Mar 13, 2011 | 04:27 AM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
So I purchased a 1986 Firebird. I had a 89 9 bolt and ls1 setup ready and bolted up to my 92 Rs. I have heard or read that pre 89 used diff fittings/threads than 89+. Is this true? What would be needed to adapt it?
Old Mar 13, 2011 | 05:01 AM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Re: Anything needed for a bolt on deal?
Check out some of the information on this link:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
Old Mar 13, 2011 | 07:01 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I assume the LS1's were the fronts. The 9-bolt is a drop-in. The tube nut threads are different at the combination valve, early 89 and late 89. If you wish to swap in larger rear brakes, Ed Miller sells the correct 1LE valve (so you'd need the second design for your 92).
JamesC
Old Mar 13, 2011 | 08:06 AM
Carlos773's Avatar
This is for the 86. The brakes were in my 92. So the difference is only on the prop valve? So everything else would be the same?
Old Mar 13, 2011 | 08:16 AM
JamesC's Avatar
Where the braking systems are concerned, there is no difference between 9- and 10-bolts. The PBR system into your 86 will require some changes. Check the following link, toward the end, for more info:
https://www.thirdgen.org/forums/tran...-10-bolts.html
In short, you'll need the first design 1LE combination valve, parking brake cables, and if you've changed rear end gearing, appropriate speedo gears.
JamesC
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
