nickle plated rotors?
Old Mar 20, 2011 | 07:45 PM
rx8camaro's Avatar
are nickle plated rotors any good? what is the point to them? are they more heat resistant? do they sqeel if pared with ceramic pads? any general input at all would be good. thanks
Old Mar 20, 2011 | 10:28 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: nickle plated rotors?
There is no benefit to nickle plated rotors. Your just going to pay more over the same thing a set of zinc washed do, regardless of the coating it is a surface that sees wear and the coatings will eventually come off the rotors surface...
They basically keep the rest of the rotors from rusting and looking nice unlike non-coated rotors that typically start rusting in the vines and rotor edges...
Old Mar 31, 2011 | 11:52 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
agreed. and if you're just concerned about the non-contact areas rusting, some high temp paint will do that for ya a lot cheaper!
Old Apr 3, 2011 | 02:00 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
The Zink will not chip or peel off. and will always look good.(car shows)
the Nickle will start to chip and flake. has rust sets in..(under it)
FOR a longer lasting finish..go with Zink. paint will chip also..IMO
Old Apr 3, 2011 | 10:43 AM
FueledSoul's Avatar
agree
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
BLK87Z
Sep 18, 2015 11:29 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
