Brake problem 84 Firebird S/E
Old Mar 28, 2011 | 12:47 AM
trucker's Avatar
Car: 1984 Firebird S/E WS6 J65
Engine: 2.8L H.O. 173 CID (LL1)(L code)
Transmission: Turbo Hydra-matic 700-R4 (MD8)
The brake indicator light is on, there does not seem there is too much that can cause it the Special Edition in 1984 has 4 wheel disk brakes that seem to be working fine, the factory installed booster is still installed the master I believe was replaces several years ago I do not know if the calipers have ever been replaced, I only see one sensor next to the master. any ideas as to where I should start???
Old Mar 28, 2011 | 06:56 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Brake problem 84 Firebird S/E
Originally Posted by trucker
The brake indicator light is on....
The light usually indicates a failure (leak) in the system. I'd do a visual.
JamesC
Old Mar 28, 2011 | 09:11 AM
trucker's Avatar
I forgot to mention the light is on all the tlme not just when the brake is applied, I may check the sending unit next to the master, it may be bad.
Old Mar 28, 2011 | 09:20 AM
JamesC's Avatar
Sounds like the pressure differential switch which is a part of the combination valve? If so, it's alerting you to a leak in one of the brake circuits. You might check the fluid level in the master. Or it might be something as simple as the brake light switch which is located above the brake pedal.
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
