Best brake kit for road racing
Old Apr 12, 2011 | 09:23 AM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
I am slowly building a road race car - 89 camaro RS with Lt1/T56 for CMC2 NASA class and am wondering what you guys think would be the best brake setup to run? From everyones reviews i'd like to order from flynebye (Ed) for the ease of getting everything as one kit. Any ideas/suggestions?
edit - here are restrictions:
- cast iron rotors vented only - no slotted or cross drilled
- max front rotor 13.1" dia and 1.31" thickness max
- 12" dia with 1.25" thickness max allowed
- i can use any front caliper single line aluminum bodied with 4 or fewer pistons readily available to public from retail source for under $600. modifications to spindles allowed for caliper mount.
- rear can use any front caliper updated/backdated of same manufacturer/model
Old Apr 12, 2011 | 08:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Best brake kit for road racing
what wheel diameter are you limited to? thats important too.
you can do quite well with c5/c6 front brakes, parts are cheap and easy to get, but need 17" and larger wheels.
Old Apr 12, 2011 | 08:38 PM
Car: 1992 z28
17" wheels are allowed for cmc2 so i should be good! this is all part of a planning process for budgeting so if something new/better shows up down the road i may switch over but for pricing purposes this should be good.
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
red90IROCls1
Aug 25, 2015 06:56 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
