park brake adjust
Old Apr 18, 2011 | 07:35 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
park brake adjust
I have the over driveshaft adjustment. the problem im having is that it looks like the pass. side rear cable is slightly longer than the drivers side. can i just adjust out? will there be even pressure?
Old Apr 19, 2011 | 01:36 PM
Re: park brake adjust
Sounds like maybe it's either not in the little "track" kind of feature welded to the bottom of the car along the back seat floor well on that side, or is missing the S clip that holds it up on that side nearer the rear, or both.
When fully and properly installed, they're close enough in length that they'll self-equalize.
Old Apr 19, 2011 | 02:42 PM
Red 87 GTA's Avatar
ill look again later but i believe that the both are in the proper locations
Old Apr 19, 2011 | 03:31 PM
Badasscamaro346's Avatar
Car: 87 camaro
Engine: v8 carb'ed
Transmission: 5 speed
checked mine out today when messing with my exhaust and mine looks to be doing the same thing. They are both installed correctly but one looks longer than the other.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
