Baer Pro + Fbody pics
Car: 88 Trans Am Hardtop
Engine: 350 L98
Transmission: Stock 700R4
Axle/Gears: 3.27 Aussie 9
Current tires: Goodyear F1 GS D3s
Big Brakes!
"New" but old wheels:
17x9.5 on all 4 with 275/40 G-Force KDs. 5.5 back-spacing in the rear, 6.0 up front with a half inch spacer. The other three wheels should be done in 2-3 weeks so hopefully I'll have everything mounted shortly thereafter.
Big Brakes!
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Baer Pro + Fbody pics
Awesome to see that those wheels fit over those brakes so easily!
Do you have a weight figure for each wheel - no tire?
Engine: 350 L98
I can weight a wheel too before I mount the tire.
This is the 13" Baer kit.
Engine: 350 L98
If you're asking about track width I'll have to get back to you.
I had one 17x9.5 wheel sitting around from my old Trans Am that I used with the Baer template to make sure the 6P calipers fit. The template showed I needed a half inch spacer to clear the calipers, so I ordered a set of front wheels with 6.0 inches of back spacing. 6.0 bs + 1/2" spacer = 5.5 bs fitment.
How about a quick measure of the placement of the outside of the tire with the top of the wheel arch?
Engine: 350 L98
I am pleased the brake pedal travel is normal length. I thought with a stock cylinder and the added brake fluid capacity of the calipers the pedal travel would increase a lot.
Engine: gone
Transmission: gone
Axle/Gears: gone
man that's a nice setup you got there the car looks great! great work!
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
Looks great!!! did you have the "firehawk" onto the caliper? did you make any major mod to the spindle's?
Engine: 350 L98
Car: 1992 Camaro
Transmission: t-5
awesome, if you dont mind me asking where did you get yours. i know hawks has several different kits available just having issues finding which one im wanting. stock disks and rear drums do not work!!!
Engine: 350 L98
84 TA NV
Sep 6, 2015 08:02 PM
