quick i need help fast
Old May 17, 2011 | 11:31 PM
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
so i just got done swaping a rear end in my car and i started to test drive it and noticed that my emergency brake light was on, also i noticed that my back drum brakes arent releasing. my dad told me i gotta get my brakes bled. could that just be the case?
Old May 17, 2011 | 11:38 PM
oH HorizoN's Avatar
Car: 1989 IROC-Z Camaro 'Vert.
Engine: 350, ZZ4 motor
Transmission: TH-700R4
Axle/Gears: 2.73 ... for now.
Re: quick i need help fast
Did you just swap the Diff or the entire rear end? I'm assuming the entire rear end.
It seriously might be that the E-brake cable is adjusted incorrectly, and is always on.
Old May 18, 2011 | 07:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Mentioning the year, make, and model is always helpful.
The adjustment mechanism for 82-88 cars is above the drive shaft.
https://www.thirdgen.org/forums/atta...e-adjuster.jpg
JamesC
Old May 18, 2011 | 07:33 AM
Car: '90 Camaro
Engine: 305 tbi
i wanna say it came out of a 84 camaro but did they make nine bolts that year?
Old May 18, 2011 | 07:38 AM
JamesC's Avatar
What year is your RS? Depending on year, it may or may not have the adjustment piece. The nine bolt didn't appear until 85.
JamesC
Old May 18, 2011 | 05:38 PM
Car: '90 Camaro
Engine: 305 tbi
ok so this rear has gotta be 85 and up and its a 1990rs and when i was connecting the lines up they looked the same from my old rear. and i know it does have the adjusting screw i just lube them up with bearing grease and unscrewed it to the way i took it out. i sprayed disk brake quiet on the spring and everything. im thinkin maybe it could just be that i havent bled the lines yet.
Old May 18, 2011 | 07:41 PM
Car: '90 Camaro
Engine: 305 tbi
UPDATE: brakes works and everything is in working order! for now lol
F-body-fan
Jan 12, 2023 01:49 PM
InfernalVortex
Apr 20, 2021 11:31 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
