Would this MC fir my stock booster?
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
http://www.opgi.com/p/brakes/3455/176/CH26656.html
I really like the features, and it looks great. I know my bore size is 24mm=.944". They sell this CPP unit in 1" and 1-1/8". Would that 1" one fit?
Thanks for any help.
Engine: LS3
Re: Would this MC fir my stock booster?
bump,
please help.
Does anyone know the dimensions of our booster/master cylinder attachment? If anyone knows this, then I can compare to the CPP part.
please help.
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
I'm almost positive it will "fit" but it will take a lot of fabrication to make it work. Your car has all metric fittings and the CPP one has standard fittings. You either need adapters for all your lines or you need to make all new lines. I got a similar one for my car and it comes really close to the upper strut mount. I am going the complete aftermarket route with a new adjustable proportioning valve and all new lines to eliminate the metric fittings.
Engine: LS3
I am chainging everything in the car. I have the C5 brakes already. I am running line lock and an adj. prop valve right now. I know what is needed to make this work. I don't care about that.
I really just want to be 100% sure that this will bolt to my stock booster. Thats all. Seems very hard to find that info.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
it "looks" like it will bolt to the booster, thats all
Engine: LS3
I know that already
Car: '91 1LE
Buy it. If it fits, great. If not, send it back for a refund. Comparing it to my new one I say it will work but you will need a 90* fitting for the rear line I can see in the picture. It will need to be routed straight back to clear the strut mount.
Engine: LS3
Guess that is what I will have to do. Seems crazy that there is no other way to learn if it fits....
Oh well.
Oh well.
Car: '91 1LE
If you do order one post up the results. I'm curious. If it fits I may get one too. I like how it is self contained and it would go good with the "smooth" look I'm going for.
Engine: LS3
I measured my booster and it seems like it would be close. Really depends how tight a tolerance the holes on both are holding to. I think for the $200 I will buy it and hope it fits, if not, I can return it. I will buy it tonight and let you know what happens when I get it. I will be plumbing my entire car from scratch, I will post that too.
Engine: LS3
It is on its way to my appt right now. I will be down workin on the car this weekend. First thing I will do is check if it fits. I can't tell you how badly I hope it does. I am SUPER suprised I couldn't find anyone else who has used this master. It has an adj. prop valve, is polished aluminum, built in brake light switch and a pre-pressure adjustment for rear brakes (this is different than the prop valve). Oh and NO MORE METRIC BUBBLE FLARES!!!!
I can't wait for my whole brake system to just be "normal" double flares.
Car: '91 1LE
I know what you mean. I searched a lot about modding the master cylinder but it seems like that is the one thing nobody changes. All these cars with smoothed engine bays with lots of hours of work and they still run the stock master/prop valve/lines combo!
Engine: LS3
I know!!! Its like we are the first two people in the world to HATE the stock crap.
I hate the stock plastic cover, I hate the damn metric line sizes, and I super hate that they use bubble flares!
Really hope this works.
Car: '91 1LE
I'm actually thinking of installing my line lock solenoid inside the cowl panel using bulkhead fittings for a cleaner look. I really hope that master fits because it would really simplify plumbing. Do you have aftermarket strut mounts or are they still stock?
Engine: LS3
Spohn. I don't have stock anything. The only thing left stock on my car is the body's steel - a 3" Cervini hood. Acctually that is all modded too. No side blinkers, locks, antenna, or gas door!
Engine: LS3
The good news, is it fits! The bad news is that it will take some fancy brake line bending to get it to plumb up. Either way, I am getting it in there. I will post pics tonight.
Engine: LS3
Pics are now on the last page of my cardomain site. Angle of the pics is not great. I had my gf take then while I was working on the fuel cell.
Give you an idea. The fittings will have to take a HARD 90 coming out. I think it is doable.
Genopsyde
Oct 7, 2015 08:35 PM
