ls1 brake swap, more rim BS needed?
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Swapping to ls1 front brakes, I see you lose the thickness of the rotor onto the hubs. Anyone tucking a 17x7 or 17x8 with more backspacing due to the new brake setups? Not sure if my skinnies will clear anymore due to the rotor thickness and a small spacer being needed to clear a 15" rim. Might swap to 17" skinnies or narrower fronts instead.
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: ls1 brake swap, more rim BS needed?
i run reg 92 wheels no problem but when i go to the track my skinnies would just touch a little used the wheel spacers the camaro's come with on the back for the fronts no problems since
NBrehm
Aug 25, 2015 11:49 PM
