Help problem with brakes!
Old Jun 28, 2011 | 01:07 PM
91birdofprey's Avatar
Car: 1991 pontiac trans am gta
Engine: 5.7 tpi
i have a 1991 trans am gta, when i press the brake pedal the front brakes dont release when i let go the back do. The calipers are working good. What can it be? thanks in advanced i need this car running good! thanks
Old Jun 28, 2011 | 01:58 PM
LarryL's Avatar
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
Re: Help problem with brakes!
Sounds like the master cylinder. I had same problem on my vette and it was the master.
Old Jun 28, 2011 | 06:38 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
more likely than not it's the front rubber flex lines . old ones can/will collapse internally , then act as check valves . it's common with older vechicles , i have had it happen to myself several times . it's not only G.M. vechicles , i had it happen to my 1989 dodge p/u . i have owned my truck since new . many others on this site will confirm . replace them , good luck .
Old Jun 28, 2011 | 07:34 PM
rubber flex lines
"Collapse" isn't exactly what they do, but the effect is about the same... they rust internally, and eventually completely close off the little tiny hole through the fitting.
Just change em out, and then go from there.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
overdriv
Aug 20, 2015 03:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
