brake/ maybe suspension problem
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
(and yes i did put it in both boards)
when i sometimes jump on the brakes really quickly, which because of idiots i usually have to do, i hear a strange popping like noise coming form well idk is it the suspension, brakes, my body panels hitting each other, i have looked all around the car and nothing looks out of place or messed up so.......help what makes the noise is it bad how can i fix it?
Transmission: 5spd
Re: brake/ maybe suspension problem
BUMP* it still does it now, just on and off still idk what it is or why?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
could be worn out suspension bushings, or possible a shock or strut. Any way to make a video of it?
Transmission: 5spd
not really and all the more i can say is it happens when i"m about to nail the brakes and the pedal is about a 4th of the way down, so when i just set my foot on it and i start by applying light pressure and slowly ease it on, not just stomping on them, and the noise is like a pop, not a crack or crunch or breaking sound, just like a "pop" i wish i had a better way to describe the sound, but like i said it doesn't do it all the time, so the video would be 40 mins of me driving around trying to make it happen lol it sounds like if one of the calibpers pistons had a rock it it and just spit it out or something, if that would even be possible probably not, that or theres something rubbing together and "popping" out of place cuz of a lost or loose bolt, hell i have no idea, cars so low i cant get under there to look, need to jack it up first or get it to meineke so they can put it on the lift
