Brake Problem...
Old Jul 7, 2011 | 06:04 PM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
Brake Problem...
So recently i got my brakes replaced. why:
whenever I'd brake, the car was very difficult to stop.
id have to press to hard to get the brakes to actually function right.
also there was massive vibrations from the front rotors being warped.
basically, no matter how hard I press on the brakes, it always looks like I'm coming to a slow stop at a light. - if a car slams it's brakes on ahead of me, ...id rear end them.
Parts replaced:
front and rear rotors
front pads (rear were still good)
brakes were bled
master cyl replaced (it was bad, no rear brakes prior to getting this replaced)
proportioning valve replaced
power booster replaced
Any suggestions/comments would be greatly appreciated into resolving this issue. I think it's the calipers - either clogged or needing to be rebuilt or replaced. my mechanic thinks that's a possibility, as well as swelled brake lines not allowing enough fluid through.
Old Jul 7, 2011 | 06:56 PM
Re: Brake Problem...
Calipers are CHEEEEEEEEEEEEEEEEP; like, less than $10 apiece. If in doubt, change em out.
The rubber lines fail ALOT on old cars. Not just these cars, ALL old cars. Again, if in doubt...
Old Jul 7, 2011 | 07:11 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Definitely new rubber lines - makes a world of difference!
Old Jul 7, 2011 | 09:34 PM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
cheapest I've found on calipers is $10 per caliper in front, plus $15 core charge.
$67 per rear caliper and $30 core charge
they are rebuilt as well.
(Kragen)
Old Jul 8, 2011 | 08:44 AM
55ChevyMan's Avatar
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
I replaced the front calipers the problem the left rear caliper started leaking while replacing the the rear rotor I thought it was the hard line so I replaced it with braided hose but where it leaking from is the banjo bolt it like the bolt is not long enough can I a get longer banjo bolt I got a new one from auto zone and same thing it like its too short help any body thanks
Old Jul 8, 2011 | 05:52 PM
The banjo bolt is fine; problem is the crush washers.
Put 2 of them between the fitting and the caliper, and 1 between the bolt head and the fitting.
Old Jul 8, 2011 | 07:40 PM
55ChevyMan's Avatar
went to auto part store and got 1/4 longer banjo bolt from a ford and it worked
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
