Some LS1 brake upgrade questions (searches but no answers)
Old Jun 26, 2011 | 10:48 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
For LS1 front brakes, what flexible line should I use? I ask because I noticed a difference in the line diameter when looking at the 2 side by side. By the 2 I mean the LS1 beake hose, and the stock 3rd gen one. Here's what I'm talking about: 3rd gen on right, LS on left.
Also, if I end up using the LS1 hoses I'll just extend the hard line the extra distance needed. Any harm in this that anyone can think of?
Old Jun 27, 2011 | 07:00 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Some LS1 brake upgrade questions (searches but no answers)
Might consider the following if you haven't already:
http://www.flynbye.com/catalog/i107.html
JamesC
Old Jun 27, 2011 | 12:11 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
I've been gathering information on this swap myself. From what i have read so far using the 1LE option brake lines is the way to go cause they are longer than the non-1LE brake lines. This is the first time i've heard of the line size being different.
Old Jun 28, 2011 | 10:12 AM
Car: '91 LS6/T56/9"
Engine: LS6
Funny you should mention that since I thought the same thing and ordered a pair from AZ. I'm hoping the fluid passage will be larger like the LS hoses are. AZ JUST called to say the hoses are in. Pics will be up later to let people know.
Old Jun 28, 2011 | 10:31 AM
skinny z's Avatar
I did the LS1 front brake swap and used the front flex hoses from an 86 Camaro. No issues and the hoses have the intermediate support too.
Old Jun 28, 2011 | 10:36 AM
Car: '91 LS6/T56/9"
Engine: LS6
I'm not saying 3rd gen hoses won't work, I just don't' want to create a fluid bottleneck if I don't have to.
Old Jun 29, 2011 | 09:08 AM
Car: '91 LS6/T56/9"
Engine: LS6
How long are your wheel studs?
Old Jun 29, 2011 | 09:51 AM
skinny z's Avatar
ARP 7708.
2.5" long. I had to cut off about 5/8" or use open lug nuts.
Old Jun 29, 2011 | 09:53 AM
Car: '91 LS6/T56/9"
Engine: LS6
ARP 7708.
Ummmm, that's an open lug in that pic.
Old Jun 29, 2011 | 10:19 AM
skinny z's Avatar
I did that for mock-up purposes.
I actually used open lugs for a while until I bought a new set of McGard 64012 nuts. Then I had to cut the studs down to fit.
Old Jun 29, 2011 | 05:51 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
I'm going to be using 3.25" ARP studs with my swap and the stock replacement earls' braided line kit looks like it should be a bolt in addition, plus it's what was already on the vehicle.
Old Jun 29, 2011 | 06:26 PM
skinny z's Avatar
Do your Earl's lines have the provision for support about mid length?
Old Jun 29, 2011 | 10:07 PM
Car: '91 LS6/T56/9"
Engine: LS6
Am I the only one concerned with the difference in fluid passage diameter?! The 1LE lines I ordered are the same as stock.
Old Jun 29, 2011 | 10:24 PM
skinny z's Avatar
In a hydraulic system it's not a matter of fluid flow (as in a fuel line) but in the transmission of pressure. Unless you're working with force applied (as in the caliper piston diameter) size doesn't really matter. Of course there are other variables to consider but in these applications, there won't be any measurable benefit from having larger lines. That's the way I understand it anyway.
Old Jul 6, 2011 | 04:02 PM
xpndbl3's Avatar
Car: 1984 Z28
yes the thirdgen braided brake lines have a provision midlength
doesn't matter since the brake line is similar size to that hole regardless, it's a pressure system not volume, you'll be fine
Old Jul 7, 2011 | 10:04 AM
supr_fly03's Avatar
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
I just used the factory 83 lines on my LS1 conversion. Banjo bolts for the LS1 calipers fit fine. I just had to turn the line 180 so that the line would fit flat. Works great. I even was able to use the middle line support.
Old Jul 7, 2011 | 10:14 AM
skinny z's Avatar
Same here. What I WOULD like is the same fit of the OEM rubber line in braided steel. There are plenty that will fit however I couldn't find anything with the mid line support.
Old Jul 7, 2011 | 10:36 AM
supr_fly03's Avatar
Car: 83 Z28
I dont think that I have seen any braided lines with the middle support. Have you checked flynbye?
Old Jul 7, 2011 | 05:09 PM
skinny z's Avatar
Yes. And the usual suspects with no luck.
Old Jul 9, 2011 | 07:05 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i used these no problems http://flynbye.com/catalog/i107.html
Old Jul 10, 2011 | 02:59 PM
skinny z's Avatar
I'll have to check them out. Thanks.
Old Jul 10, 2011 | 05:32 PM
tom86iroc's Avatar
Car: 1986 iroc
no problem and it uses the fatory hold down on the strut the line has an adj slider so you can mount it the way you want too
Old Jul 10, 2011 | 06:54 PM
one92rs's Avatar
Car: SOLD!!!!!
you are looking at this wrong. fluid flow is one deal. fluid pressure is another. a hydraulic system gets its pressure from restriction. not the pump itself. i would be ready to bet that you cannot tell a difference if you were to install either line and switch it. a brake system works mostly off pressure more than flow. i can have a 1/4 inch hole in a line and have great flow. or i can have an 1/8 inch hole and better pressure. ill take the 1/8 inch anytime due to the restriction being pressure.
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Jan 19, 2016 12:21 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
