89 Iroc brake problem
Old Aug 1, 2011 | 05:46 PM
cdiedrick's Avatar
Car: 89 IROC
I have an 89 Iroc, my car was puling to the center of the road when I would hit the brakes. I tore them apart, thinking that my pass side caliper would not be working. To my surprise, the rotor was not damaged aside from normal wear, and the caliper did not show any signs of leaking or seizing. Pads looked great also. Really no differences between the pass and driver side. No leaks at the brake hoses either. Any ideas?????????
Old Aug 1, 2011 | 05:50 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 89 Iroc brake problem
Pulling to one side or another often indicates a bad flex hose. The issue is internal. BTW, posting once in the appropriate forum will generally get the desired results.
JamesC
Old Aug 1, 2011 | 07:25 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Replace both front brake hoses, if one is bad the other isn't far behind....
Old Aug 2, 2011 | 05:33 PM
cdiedrick's Avatar
Car: 89 IROC
Sorry James, but been away from this site awhile, 2 is better than one. Now, J, and James, I did buy both brake hoses, and we will see what that will do. I agree with your analysis though. Looks great on the outside, but inside could be collapsing.
Thanks, Chris
kyleb24
Aug 15, 2015 08:24 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
