10bolt disc to 9bolt 1LE discs
Old Aug 15, 2011 | 10:18 PM
geoffz28's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Axle/Gears: Moser 12bolt 4.10s
Hello. I am swapping out my 10 bolt with the 10.5" discs to a 9bolt with the 11.6" 1LE brakes. I do not have E brake cables for the the 9bolt 1LE rear. Can I use the cables from the old setup? Anything else I should know?
Old Aug 16, 2011 | 06:44 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 10bolt disc to 9bolt 1LE discs
You'll need new cables. The braking systems between 9- and 10-bolts are identical, so the brake info in the following will be helpful. Note that you'll need the 1LE combination valve, cables, and perhaps speedo gears.
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Aug 16, 2011 | 09:34 PM
geoffz28's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Thanks for the reply James.
I will definitly need new speedo gears. Going from 3.27 to 4.11. Are the cables and 1LE combo valve available at napa etc. or dealership rather than from Ed?
Also is my cars braking going to be really messed up if I stick with the original combo valve for now?
Old Aug 17, 2011 | 06:38 AM
JamesC's Avatar
You should be able to purchase cables from an auto parts supplier. The combination valve may be problematic. It's been discontinued from GM, so Ed may be the only source. Of course, you could always go the after market adjustable route.
The original valve will work, but you won't experience the best from the new brakes.
JamesC
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
jrdturbo
Mar 31, 2016 02:58 PM
92projectcamaro
Dec 8, 2015 12:25 AM
KO1
16
Oct 15, 2015 05:00 PM
indygene
Sep 26, 2015 11:21 AM
