Changing Brake Booster
Old Aug 20, 2011 | 05:54 PM
TPI5speedguys's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Transmission: 5 speed
Axle/Gears: 3.08
I have read through a few posts and have come to my final likely solution for the issue of a hard pedal to press. The vacuum lines are all fine and I have changed the check valve. I was wondering what issues or anything else I should now before changing the booster? Do i need to bleed the brakes or what? Is it hard to change?
Thanks!
Old Aug 20, 2011 | 06:51 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Changing Brake Booster
no bleeding required. just unbolt the 2 nuts from the booster that hold the master on, then the other 4 nuts are under the dash. Depending on the car and the options/routing of BS under the dash, it may be easier/harder. you will need some universal joints, socket, wrenchs and extensions. Its a little tight.
Old Aug 20, 2011 | 07:37 PM
jrz28's Avatar
Car: 1984 Berlinetta
Engine: 305 Carb
I have read some people have had a hard time changing them, but like said above I guess it depends on the car. Just did my 84 Berlinetta and took me less than an hour.
Old Aug 20, 2011 | 08:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
getting the one out of my 86 was a complete disaster/nightmare. my 92 on the other hand, quite simple.
Old Jun 4, 2012 | 04:19 PM
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
That's good info, I need to replace mine on my 92rs.
Is there any difference between the v6 and v8 boosters?
There isn't a difference. I asked like 3-4 of the guys at the parts store to look it up for both. It carries the same part #.
Old Oct 28, 2012 | 05:30 PM
84firebird1996's Avatar
Car: 1991 Trans Am GTA
Engine: LT-1
DId the Brake booster solve your problem?
Terrell351
Jun 13, 2021 01:13 PM
kyleb24
Aug 15, 2015 08:24 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
