Piston tool for rear cast iron calipers
Old Aug 29, 2011 | 05:11 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I need to screw the pistons back into the cast iron rear calipers on an 88 GTA to make room for new, thicker pads and rotors.
I want to buy the correct tool. I beleive it's a 2 1/8 piston, but I'm not sure, and it's a PITA to remove the caliper just to measure. I also do not want to buy a complete rear disc service tool set, just the appropiate tool for this job.
Can anyone recommend a tool manufacturer, with part number? Link with pic would be fantastic.
Thanks in advance.
Old Aug 29, 2011 | 06:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Piston tool for rear cast iron calipers
The Delco-Moraine rear iron caliper has a piston OD of 48 mm, according to LukeSkaff, if that helps.
JamesC
Old Aug 29, 2011 | 06:23 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Thanks in advance.
If you're just doing this once, give your local Advance Auto or Autozone a shot; they have the correct tool in their loaner sets and it just requires a refundable deposit. I had to replace the pads (and turns out the calipers too, pistons were frozen on both) and went this route since I knew I wasn't going to be using the tool more than once or twice ever. Money better spent elsewhere
Old Aug 29, 2011 | 07:25 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Can't you just use a large C clamp? I've always just used a large C-clamp to push piston inwards to add new pads.
Old Aug 30, 2011 | 06:53 AM
JamesC's Avatar
IIRC, a C-clamp can be used on the fronts, but not the rears (for standard Delco-Moraine calipers).
JamesC
junkcltr
Aug 2, 2019 11:12 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
