Proportioning Valve identification?
Old Sep 20, 2011 | 04:04 PM
Spdfrk1990's Avatar
I have a few proportioning valves and I could of swore 1 was off a 1le car but I cant remember which 1 and not sure how to identify them?? Can you tell by the numbers on the side of them?
Old Sep 21, 2011 | 06:29 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Proportioning Valve identification?
IIRC, no. The differences will be internal, but I'm uncertain what those differences are. Perhaps another member will step in with the info, as it would be interesting.
JamesC
Old Sep 21, 2011 | 06:39 AM
Twin_Turbo's Avatar
I'm pretty sure the only difference is disc/disc or disc/drum. The diff between those is the disc drum combination valve has a proportioning valve and a hold off valve (holds off pressure to fronts until rear drums grab, this is for stability...drums are slower to operate as discs have pads close to rotor), the disc/disc one doesn't have this.
Old Sep 21, 2011 | 06:43 AM
JamesC's Avatar
I've read that each system has increased bias: disc/drum, standard disc/disc, 1LE disc/disc.
JamesC
Old Sep 21, 2011 | 08:43 AM
Spdfrk1990's Avatar
Its been awhile since I have been into this but I also didnt think the 1Le valve only came on 1le cars. I know some of the threads are different also between the years.
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
