found LS1 brake conversion cheaper
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: found LS1 brake conversion cheaper
Count me in for two i will also give you a cardboard of a cutout of the rear brake bracket a fellow thirdgen member made for me.
sent you a PM sickRS
so we have...
wht96 - 1 set
SiCkRs - 2 sets
patricklav - 1 set
Need one more set to make it happen. I might be able to get the same pricing with 4 sets as well. We'll give it a week or so before I need payment and put the order in.
so we have...
wht96 - 1 set
SiCkRs - 2 sets
patricklav - 1 set
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Just got my goods in today!
Nice packaging, and the hubs and brackets look great!
Thanks Jake!
Thanks Jake!
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
yes I could do another run. Or even just one set. What all do you need done?
I actually have an order into the water jet right now so I could add some stuff on.
Send me a PM.
Send me a PM.
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
i too would take a set if you make another run, pm me if this happens
I will do another run. I heard back from my waterjet guy and I can do them for $65 a set shipped in the US. I plan to put the order in at the end of this week so if you want a set you need to pay by Friday morning or let me know via PM when you plan to pay. paypal to jake@classicdaily.net . Be sure to put what you are buying in the notes, also in the subject if possible.
The brackets are cut on a waterjet out of 3/8" mild steel.
PM me if you have any questions. thanks, Jake
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
I currently have a 91 rs.
Im lookin to upgrade to ls1 fronts calipers.
I have a set of ls1 calipers and rotors. What basic parts do i need?
Also i have a.moser 12bolt with gm single piston cast iron calipers.
Im lookin to upgrade them to ls1 calipers and rotors also if possible.
I have the ls1 rotors and calipers front/rear
For the fronts you need the bracket (what I am selling) in addtion to the ls1 calipers and rotors. You also need to take your original rotor/hub combo and remove the actual rotor part and turn it down to fit inside the LS1 rotor. I can have this done on a lathe by you either sending me your old rotors or I can buy new ones near me. New might be cheaper rather than shipping. Converting them from rotors to hubs runs $60.
I am not sure about a conversion for the rear..... I would have to have it all in front of me to be able to figure it out for you.
Remember if you want a set of brackets I need payment by tomorrow morning. Or at least a PM telling me you want a set and when you will pay. I will not be cutting any additional brackets.
will also take a set pm sent.
I'm going to order mine from flynbye its been like a year I need them now.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
I'm in for a set if you are still making them.
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
just thought id add that after a year of buying these conversion brackets i finally got around to getting them on last night and they both line up great.
Good price and quality, Thanks.
Car: 1991 Z28 convertible camaro
Engine: 383 superram
Transmission: Level 4 Vigilante 3000
Axle/Gears: 3:42,Torsen, moser axles LPW girdle
Do he still offer the brackets or kit for sale? Any email contact to get in touch?
Thanks,
Patrick
Thanks,
Patrick
Axle/Gears: '01 3.42 10 bolt
guys, i would recommend going to http://bigbrakeupgrade.com/. Scott is great with fast shipping.
Car: 87 Trans Am
no offense to scott but those are expensize i dont have that kind om money laying around how ever i have 60 bucks laying around
Mine are 59.00 but the shipping does put it over 80... New special for 3rdgen.org guys..
59.00 shipped continuous usa ! Just email me for the deal C5 or LS1
I need some back brakes brackets 9 bolt lt1 or ls1 brakes
