ls1 hubs
Old Dec 7, 2011 | 03:13 PM
moedaman's Avatar
ls1 hubs
Is there any way to make ls1 hubs work? I was confused about hubs and bought ls1 hubs from a junk yard thinking they would work. Thanx in advance..
Old Dec 7, 2011 | 06:03 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: ls1 hubs
no.you have to modify the third gen hubs.
Old Dec 7, 2011 | 09:22 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: ls1 hubs
completely different spindles, no way interchangeable. any local machine shop should be able to cut down a set of factory 3rd gen non-1LE rotors to correctly add the LS1 brakes to your car. grab a set from a local junkyard, shouldn't cost much and you can keep driving your car while you're collecting parts for the upgrade
Old Dec 7, 2011 | 09:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: ls1 hubs
Nope. You don't want them anyway, 3rd gen front hub setup is superior. Like the others said, you have to have a set of 3rd gen rotor/hubs cut down into a hub. Basicly cutting thr rotor off and just keeping the hub with the wheel studs.
Old Dec 8, 2011 | 10:55 PM
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Re: ls1 hubs
They should look like this after being machined down.
Old Dec 8, 2011 | 11:05 PM
gp90gta's Avatar
Car: 1990 GTA
Re: ls1 hubs
I actually did this at work last year for a friend, I used a regular brake lathe, I first cut the rotor so thin it came off the hub, then I make a bracket to hold the rotor cutting bit and slowly cut the hub down, worked great.
Old Dec 9, 2011 | 05:45 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: ls1 hubs
Why is the 3rd gen hub superior?
Old Dec 9, 2011 | 06:18 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: ls1 hubs
They are servicable and use tapered bearings instead of ballbearings. they are stronger and last longer.
Old Dec 9, 2011 | 06:31 PM
zenish's Avatar
Engine: 305 tbi
Re: ls1 hubs
forth gen uses ball bearings?
Old Dec 9, 2011 | 08:03 PM
Doug Phillips's Avatar
Car: 85 IROC race car
Engine: 425/435 rwhp/tq
Transmission: WCT5 .80 5th gear
Axle/Gears: 3:42
Re: ls1 hubs
4TH gen guys that are tracking their cars are having hub failures. There are a fewguys out there making hub conversions to use the 3rd gen set up.
Old Dec 9, 2011 | 08:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: ls1 hubs
Yup, having a wheel come of at speed wil ruin you day.
Old Dec 9, 2011 | 08:53 PM
Axle/Gears: 3:42
Re: ls1 hubs
Buddy had a 92 Vette race car. He hada hub failure in corner 1 at Mosport at about 120 mph. Wheel came off and he kept it straight and off the wall. Wheel actually rolled up behind the car for easy retrieval. About $1500 in suspension and body damage. Lucky day!
It was a new hub with only 8 laps on it!!
Old Dec 9, 2011 | 09:01 PM
Car: 1992 Camaro RS
Re: ls1 hubs
Thats fascinating... hard to find info like that published anywhere.
Kinda like how I was hearing the C6 Z06 brakes arent as good as the C5Z06 brakes... but I cant find any references to that anywhere now... something about using the same rotor on both sides and one side overheats...?
Newer isnt always better I guess....
Old Dec 10, 2011 | 10:09 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ls1 hubs
That is likely as many of the C5/C6 Corvette rotors are side specific. They use curved vanes for better cooling, as long as it is on the correct side of the car.
RBob.
Old Dec 10, 2011 | 11:54 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: ls1 hubs
RBob.
I haven't checked, but I hear one of the zo6 rotors is vented backwards from .the factory. Causing overheated brakes when pushed hard
Old Dec 10, 2011 | 12:03 PM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Re: ls1 hubs
The C6 Z06 fronts are not side specific, thus one side will be vented backwards. The C5 rotors are side specific. I haven't heard of over heating, but the possibilty makes sense.
Old Dec 10, 2011 | 01:23 PM
Car: 1992 Camaro RS
Re: ls1 hubs
Here's a random mention of it on the internets:
http://forums.corvetteforum.com/1554418820-post5.html
Sorry for derailing the thread.
Old Dec 10, 2011 | 05:25 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
Re: ls1 hubs
wasnt there a sticky on exactly what needs to be done to the thirdgen hubs step by step?
Old Dec 10, 2011 | 05:58 PM
zenish's Avatar
Engine: 305 tbi
Re: ls1 hubs
http://lukeskaff.com/?page_id=404
Old Dec 10, 2011 | 06:11 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Re: ls1 hubs
yep thatd be it
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
