ls1 lines and fittings ?s
Ok couple of ?s..What size fitings? where to buy the T block and hose on the rear diff? And can i use a double flare on all my brake line connections,instead of a bubble flare? Thanx in advance..BTW i will be using plain steel brake lines from the parts house..
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: ls1 lines and fittings ?s
the fittings are 10mm 1.0 and you need to use bubble flares. They are easier to make, the tool is just as cheap as a double flare tool, and they are made in a single process where double flare takes 2 processes to make.
t block can be had at the local parts store, any one from 85ish to 2002 will work. 3/16 line works fine, but the factory stuff is 4.75 mm.
ambainb
Apr 25, 2016 09:21 PM
