Frustrating brake problem...
Old Jan 14, 2012 | 12:24 AM
severedknight7's Avatar
Car: 1986 Pontiac Trans Am
Engine: 305 V-8
New to the forum and glad to be here! Just acquired a 1986 Trans Am, and I am having some brake issues. Similar to other threads I have read but I will put my experience down anyway. Spongy pedal and had to pump 2 or 3 times to have proper brake performance. I bled all of the brakes in proper order and still have the same problem. I bought a new master cylinder and some speed bleeds... still have no brakes, yes i bench bled the new master cylinder. Now I may be focusing on the combination valve, but have a question...Do these things actually go out? And if they do, would they cause this type of problem? any help or opinions on what to do would be MUCH appreciated. And by the way...AWESOME FORUM!
Old Jan 14, 2012 | 10:53 AM
Engine: 305 V-8
Re: Frustrating brake problem...
Wow, thanks for the help.
Old Jan 14, 2012 | 11:00 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Many members find that they have to bleed the brakes multiple times before achieving a good pedal feel. I'd start there. Can't hurt. I'd be skeptical of the combination valve being faulty.
JamesC
Old Jan 14, 2012 | 11:22 AM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Take it easy bro.
You posted your question at 1:30 in the morning.....
Old Jan 14, 2012 | 11:35 AM
Engine: 305 V-8
i know it was early, lol. not trying to be an ***. and one more question about the combination valve. i noticed a fairly large bolt on the front of it. do these things need to be bled too?
Old Jan 14, 2012 | 11:46 AM
JamesC's Avatar
No.
JamesC
Old Jan 14, 2012 | 03:24 PM
Engine: 305 V-8
alright, i got it figured out. I want to warn everyone off of Dorman speed bleeders. The thread sealant on them prevented me to tighten them enough to bottom them out, and one of them actually broke off. So, instead of getting those things, I would just recommend getting quality stainless steel bleeders, they are cheaper than the speed bleeds, and they don't have that crappy thread sealant. I now have brakes, and thanks to James C for the input on the comb valve. CHEERS!
Old Jan 14, 2012 | 03:50 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Another thing is if you have drums in the rear make sure they are properly adjusted. Improperly adjusted shoes will give you a soft pedal first application and it will tighten up if you pump it. As far as spongy pedal, it took me three bleed sessions on three separate days working on all four wheels plus both master lines to get a decent pedal feel. And I still feel like it could be tighter, but it also could be the guts of the master wearing out. Good luck
gta892000
Aug 11, 2019 11:16 AM
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
