help identify these PBR calipers
Old Jan 18, 2012 | 06:34 PM
lawdog49's Avatar
Car: 91 Z28
ok, got these with a bunch of other stuff off a 94 LT1 z28. I got the complete rear with PBR brakes, so I don't know if these are front calipers or from something else. I want to do a brake upgrade to the front of my 91- so wondering if I can use these easily with some other kit parts. Any help in ID would be great- searched these numbers but haven't found a good answer yet.
Size:  86.5 KBName:  2011-06-10180909.jpg
Old Jan 18, 2012 | 07:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: help identify these PBR calipers
lt1 cars have the same front brakes as we do. those are pbr's, and if they are 1 piston, they are rear calipers, they will not work on the front.
Old Jan 18, 2012 | 09:39 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Just a quick FYI. 84-5ish corvettes had 1 piston front PBR calipers.
If the OP could get a pic thats closer of the caliper. Please post a pic of the whole caliper. that would b very helpful.
Old Jan 23, 2012 | 09:17 PM
lawdog49's Avatar
Car: 91 Z28
here is a pic of them. let me know what you think. i am trying to figure out what i want to do for a front upgrade- sounds like it will be hard to get stuff from Ed these days. i think i will need a 1le valve though- gonna use my 4th gen rear with 12" rotors and pbr calipers.
Old Jan 23, 2012 | 09:49 PM
TTOP350's Avatar
Those are the very early (84-??) corvette single piston caliper..
Old Jan 24, 2012 | 08:07 AM
lawdog49's Avatar
Car: 91 Z28
ok, so not worth too much in my effort to swap in some bigger front brakes- right? they are in the toolbox on my trailer- which is in another state right now- so i wasn't sure about single or dual piston and couldn't go look- just had these pics already taken. thanks for the help. maybe Ed will answer my email about some LS1 brakes
Old Jan 24, 2012 | 08:22 AM
TTOP350's Avatar
They will work but Im not sure if the mount is the same as the more common calipers..
Any chance of getting a pic of them flipped to see the side with the pads on it??
Old Jan 24, 2012 | 08:44 AM
Twin_Turbo's Avatar
ttop is correct, they are 84 vette calipers...in other words...junk
Old Jan 27, 2012 | 08:02 AM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
Twin_Turbo in a way there not junk cuse there lighter then the iron ones i would tak alum any day over iron let me know what you do with them dont just toss them
Old Jan 27, 2012 | 08:50 AM
Twin_Turbo's Avatar
ever driven an 84 vette? I owned a Z51, the stock JL9 calipers on later years don't brake worth a damn, the J55s are decent/good. These...they are just terrible.
Old Jan 27, 2012 | 11:36 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
From the pictures they appear to be cast iron. Could be wrong, but... just saying.
RBob.
Old Jan 27, 2012 | 02:11 PM
Twin_Turbo's Avatar
They are alu, single piston vs dual on the later years
Old Apr 6, 2020 | 08:42 AM
Billybobrr's Avatar
If these are junk then what replacement calipers are available. Thks
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
the_hamturdler
Sep 30, 2015 12:50 PM
dbrochard
Sep 25, 2015 04:56 PM
///DAN///
Sep 25, 2015 02:15 PM
Abubaca
Sep 20, 2015 09:35 PM
