9 bolt iron caliper springs different???
Old Jan 24, 2012 | 01:18 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I pulled apart my 9 bolt iron calipers and found the large piston springs are different. One is 3.25 inches and the other 4 inches in length and the shorter one feels stiffer. Is this normal? Is one correct and the other not? Does it matter which side they go on? Everything else looks identical between the two.
Old Jan 24, 2012 | 07:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 9 bolt iron caliper springs different???
Interested, I checked both my Parts & Illustration Catalogues, but neither showed different balance springs.
JamesC
Old Jan 24, 2012 | 10:56 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
They looked original too. Does the catalog give the dimensions of the 'standard' one?
Old Jan 24, 2012 | 11:07 AM
JamesC's Avatar
No dimensions unfortunately.
JamesC
Old Jan 24, 2012 | 12:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
One is the spring from the old, flawed design, and one is from the new, "fixed" design.
Old Jan 24, 2012 | 12:21 PM
JamesC's Avatar
Wondered if that might be the case.
Info/pics below that might be helpful:
http://www.flynbye.com/catalog/i208.html
The GM part number listed in the link is still good at GMPartsDirect if you have need.
JamesC
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
