99 LS1 Rear Swap. Which Prop Valve?
Old Feb 20, 2012 | 09:45 PM
vistageek92's Avatar
Car: 1984 Camaro Z28 Clone
Engine: Bored .030, vortec sbc350
Transmission: Built T5 WC
Axle/Gears: 1999 Torsen 4:10 Locker
Really confused from reading threads and threads on which valve to go with. Do I go with a 4th gen or a 3rd gen? I keep getting pointed to this one:
http://www.flynbye.com/catalog/i160.html
But then again I hear not.
Really could use some help on this one guys, why don't we have a tech article or sticky on this?
JamesC, Thoughts?
Old Feb 20, 2012 | 10:20 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: 99 LS1 Rear Swap. Which Prop Valve?
Keep your stock one & judged from there if you think it needs to be changed. some change theirs, most don't.
Old Feb 20, 2012 | 10:21 PM
Mine are rear drums, so I KNOW it needs to be changed out.
Old Feb 20, 2012 | 10:22 PM
So do I just get a stock disk/disk prop valve?
Old Feb 20, 2012 | 10:50 PM
Car: GTA
I've seen people even keep the disc/drum valves but if your changing anyways, go for disc/disc.
Old Feb 20, 2012 | 11:02 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
I drove cars with both set-ups i couldn't tell them apart.
Old Feb 20, 2012 | 11:07 PM
Well shoot. Maybe Ill just stick them on and see how it goes and if i dont like it go with a full adjustable setup.
Old Feb 21, 2012 | 06:27 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's my general response:
There's no single combination valve that fits all applications (if there were, no discussion would be required); instead there's a combination valve for each of the three braking applications: disc/drum, disc/standard disc, and disc/1LE--each increasing in rear bias. Different part numbers for each valve and so on. Best bet for best braking performance is the correct valve for your application. Or an adjustable.
Since you have an 84, the following is what you need (providing that your 84 has the new style alum block valve):
http://www.flynbye.com/catalog/i40.html
You can read more about the combination valves below:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Feb 21, 2012 | 09:17 AM
Thanks James.
Why the huge price difference between this: http://www.flynbye.com/catalog/i160.html
and this: http://www.flynbye.com/catalog/i40.html ?
Old Feb 21, 2012 | 09:28 AM
JamesC's Avatar
Note that one is a modification to your valve, the other is a new valve altogether.
JamesC
Old Feb 21, 2012 | 09:33 AM
JamesC
ahhh, the picture threw me off. Thanks for directing me to the right direction, James! Spent several hours last night going through threads trying to find the answer before starting this thread.
Old Feb 21, 2012 | 10:38 AM
Found this on rockauto $30 cheaper... That look like the same part?
http://www.rockauto.com/catalog/raca...&parttype=1888
Old Feb 21, 2012 | 10:59 AM
JamesC's Avatar
Doubtful. It says it's for 86-89 cars without 1LE. You need GM part number 14089496, which is what Ed Miller sells.
JamesC
Old Feb 21, 2012 | 11:43 AM
JamesC
Old Feb 26, 2012 | 10:55 AM
I got the valve in and almost all the way installed. One question. The very front line on the prop valve went in at the front of the valve. The new one has that one plugged and there is a new connection on the bottom. Do I run the front line into the front again or into the bottom now?
Old Feb 26, 2012 | 11:00 AM
JamesC's Avatar
Sounds like you have the old-style iron valve (note what I say in post #8). If that's so, the threads may be SAE. Double check.
JamesC
Old Feb 26, 2012 | 11:06 AM
JamesC
All the other connections went right in. Threaded perfectly. Just wondering about this one connection. Does it come in on to the bottom of the valve now, or the front like it used too.
Old Feb 26, 2012 | 11:17 AM
Im going with bottom since all the pics I can find of the J65 valves have the two lines coming from the top, from the resevor, then one on the back and two on the bottom.
Old Feb 26, 2012 | 11:19 AM
JamesC's Avatar
Bottom.
Here's what Dan Burke says about his 84:
"Mine required some relocating of the rear disk brake line: My old combo valve had the line coming in the front, whereas the 1LE piece had it coming in from the bottom of the valve. My existing line bent with no problems."
JamesC
Old Feb 26, 2012 | 06:15 PM
Bottom.
JamesC
All installed. Just cleaned everything up. Drove like a dream, amazing the difference in acceleration that new rear made. Brakes are amazing. Never has it braked so smooth and so light on the pedal. Very happy. Just need to tighten my ebrake up a bit. Might be able to get away with tightening it up at the brakes and not have to crawl up under the car again.
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
NBrehm
Aug 25, 2015 11:49 PM
sreZ28
Aug 14, 2015 07:48 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
