LS1 Rear End T/A brake size fittings.
Old Feb 29, 2012 | 01:42 PM
eddiespice's Avatar
Car: 1991 Camaro
Engine: Carb'd 305 V8
Transmission: Turbo 350
Hello,
I've been lurking for a while and this website has definitely helped me figure out a bunch of stuff.
As far as the thread though, I recently acquired a 99 Trans Am rear end for a disc brake swap. I think I've got the parking brake stuff figured out, but searching through the forums it seems the hydraulic brake lines are always referenced as the same size for both sides going to either caliper from the flex hoses, but i used a caliper and they are definitely different sizes. Does this have something to do with the possibility of this rear end having TCS? or it being a WS6?
Rather than trying to best guess what thread/diameter they are can anyone point me in the right direction so I can go get lines and adapters to fit into my 91 Camaro brake t-block.
Pics included as well.
Thanks.
Attached Thumbnails LS1 Rear End T/A brake size fittings.-iphonepics-027.jpg   LS1 Rear End T/A brake size fittings.-iphonepics-028.jpg
Old May 25, 2013 | 09:00 AM
pacamaroman's Avatar
Car: 1983 Camaro Z28
Engine: soon to be an LS1
Transmission: soon to be a T56
Axle/Gears: 9 inch rear 3:70
Re: LS1 Rear End T/A brake size fittings.
I'm sorry to bring an old thread up from over a year ago, but this is exactly what I'm facing now and it wasn't answered here. The only difference is that I don't have the 2 lines that attach at the bracket near the center front of the axle that presumably connect to the car. What parts will I need to complete my brake lines? This rear is going into my 1983 Z28. Thanks in advance for your help.
Old May 26, 2013 | 05:50 PM
eddiespice's Avatar
Car: 1991 Camaro
I sent a message to your email, but to answer I did end up just taking the lines out of both rear ends and taking them into auto zone and fitting the connectors And making my own lines. The lines were inexpensive. I don't remember the size of the fittings but a guy helped me out at auto zone. I rented a brake line bender and sorta followed the 4th gen lines. I have not worked on the Camaro in a while otherwise I would jack up the car and take a pic. Hope that helps.
Old May 26, 2013 | 11:06 PM
Thanks a lot man!! I got your email too!! I'll be heading there in the am!! Take care Buddy!!
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
novaderrik
Aug 10, 2015 12:44 PM
