position of the weights on drum brakes
Car: 91 formula
Engine: 5.7 not o.e.
Axle/Gears: 273 2 wheel drive
My problem is before I read the manual, I took the drums off, then after checking the manual I see you are suppose to mark the drum in relation to the axle. After looking at the drums, I noticed there are weights on the drums... Does anyone know what relation the drums+weights go to the axle?
I still have the other drum on the axle if that helps.
I still have the other drum on the axle if that helps. Joined: Aug 2006
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: position of the weights on drum brakes
the weight is just to balance the drum i assume, i have never marked or even taken notice of any of that. Just put them back on a go.
I still have the other drum on the axle if that helps.Thread
AkDrifted
Aug 17, 2015 07:45 PM
