Need help to figure out which rear end I have.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Need help to figure out which rear end I have.
your leaving alot out, you said its a borg warner 9 bolt. are you switching to rear disc? are replacing pbr's ?
I have already switched my rear end...im curious to know what year iroc it came out of. Are all 9 bolt rear calipers interchangeable?
Engine: Lb9
Transmission: M20
the early calipers were cast iron the 88-92 are aluminum they use different mounting brackets and rotors
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Are you sure about the start year? I have a rear end out of a notchbach 1988 GTA with the 10.5" rotors and iron calipers
Engine: Lb9
Transmission: M20
if yours are cast iron than still the j65 option maybe the start year of the pbr's were 89 I can't remember.
I'm guessing 89 was the full year with transition pbr's in late 88?
88 AFAIK got the Saggy brakes. No PBRs unil 89 except in the 4 (!) 1LE cars, and maybe the Players ones, I don't know much about those.
Bottom line is, if the calipers are aluminum and the rotors are 11.7", they're the 89-up PBRs; if the calipers are cast iron and use the same pads as the front and the rotors are 10.5" (same as the front) they're the 88-back Saginaw.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
novaderrik
Aug 10, 2015 12:44 PM
