bleeder screw direction
Old Mar 17, 2012 | 08:08 PM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Guys, on the 1le front calipers, are the bleeder screws supposed to point up, or down?
Old Mar 17, 2012 | 08:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: bleeder screw direction
think about that one a little bit. whats heavier, brake fluid or air, where will the lighter of the two want to go, where will the heavier want to go....
Old Mar 17, 2012 | 11:20 PM
Manic Z's Avatar
I'll assume that means the screw needs to be up top.
What about the retaining pin? Top or bottom? Or does it matter?
Old Mar 18, 2012 | 07:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Perhaps a pic (click on the thumbnail):
https://www.thirdgen.org/forums/vbga...do=view&id=956
JamesC
Old Mar 18, 2012 | 10:59 PM
Manic Z's Avatar
Thanks for the pic James.
I flipped my caliper/carrier from drivers side to passenger side and vice versa, so the bleeder screw is on the top. But now my retaining pin is also on the top.
Is this a problem?
Old Mar 19, 2012 | 06:11 AM
JamesC's Avatar
Is this a problem?
Perhaps you should have left the carriers in place and swapped the calipers from side to side.
JamesC
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
3rd gen money
Oct 11, 2019 09:57 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
